You guys got me to thinking here, and I just thought of a really clean way to install hardwired U/C lights:
Use plain-vanilla Wiremold. Connect to the 1/2" knockouts using Wiremold's B8I transition fittings. You end up with an installation that's much neater-looking (IMHO) than MC or NM.
Edited to add: I'm referring here to the portion that's underneath the cabinets, not wiring that's behind cabinets or inside walls. For that, use whatever your favorite method is, and either run it to the first light, or transition to Wiremold when you come out of the wall. Then run Wiremold between all the lights in a run.
[This message has been edited by SolarPowered (edited 07-03-2005).]
