thank you Webmaster [Linked Image]
perhaps a pix helps this thread
pix#1
is the pole & x-formers above the meter on pix #2 below it
i may be wrong on the two wires, that lower one must be a noodle there...?
pix#2
is the wonderful 3 ph meter arrangement, 2 service laterals, the LB has the single phase , and yes it's double lugged under all but the high leg..... [Linked Image]
pix#3
is the pumphouse, the disco you see is a fused nema3R. There was no external disco before, but it seemed like the thing to do as the pipe was cracked and wires were exposed.
you can see the chain link fence to the right, which continues onto
pix#4
and the poolhouse
(i don't know why those digitals do this, it looks like high winds, and i turn perfectly good shots of people into looking like gumby...)
