I did some load calcs for a residential triplex. Each unit totalled 50 amps. The house load was 55 amps. The service load totalled 174 amps. The building is in an undergrounded area and the only service voltage available is 480 volts, single phase. I want to install: A 100 amp 480 volt safety switch. A 50 KVA transformer to supply the 120/240 volts. A meter pack rated at 200 amps. 4 - 60 amp panels. Think it will fly? Thanks Bob
