I have seen a "neutral block" installed in a 10x10 troff (wireway), the #12 & #10 neutrals terminated on the "block" and a #1 neutral from the "block" to the neutral bus in the panel.
I have also seen the same arrangement with grounds terminated at the troff, and a larger ground terminated at the panel.
The above jobs were inspected and approved
