We use the Brady LS2000 and either vinyl labels (frosted/clear) or Permasleeves. I guess your problem is similar to what I deal with on my Brother P-Touch at home. I try to print several at a time with a few spaces between them so I mimimize the header/footer waste. If you don't need both ends of your cables marked and need every marker serialized, I guess your stuck with the waste.
Joe
