Knife to cut foil shield - I don't see that as the proper tool at all. Or for stripping either. Not sure of what cable you're dealing with but RG and CAT type cables have purpose built strippers that cut the foil as well - and if all else fails dykes would be a far superior tool than a knife for the purpose.... Just due to risk of damaging conductors if not ones self.
I'll now say that my utility knife is dull as dirt, and I like it that way! I strip NM, and larger THHN with it all the time - sheet rock too. (If I absolutely have to change the blade I run it through some sheet rock to get it to its proper dullness....) As it only needs to be sharp enough to score insulation, slightly sharper than a butter knife will due. I also have a (dull tipped/barley sharp in back) birds bill knife that I use too. Neither will cut skin with any ease, and have not cut myself with them in any recent memory.
That said I mash my fingers and slash myself more on light fixtures, or pulling wire, or pinch a blood blister with my linemans more than anything else. As the saying goes, it not 'work' unless you have to tape up a finger or two. It's part of the job....
![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif)
Yesturday, I forgot to let the grinder disk stop spinning and let my pinky get in the way. A little corner of a napkin and some Super 35 - finish drinking the coffee and back to work.... (FYI Super 35 doesnt leave a residue as much as Termiflex does.)
