I would be very surprised if the equipment would not operate fine on 208 or 240.
That said if you want to get closer I suggest using an inexpensive buck/boost transformer.
You should be able to boost the 208 very close to 220.
I assume this equipment is imported?
Will it run on 60 Hz?
