The thing to keep in mind is that a listed 15 amp receptacle is designed and tested to be used on a 20 amp circuit.
I'd bet that there must be at least some makes of 15A receptacles which are manufactured with exactly the same T-slot contact as the 20A version but are just assembled with a different plastic front (with only parallel slots).
