Hello to all,
i wanted to know if anyone has used an outside load center before. I have a home that i am upgrading an old 100 amp service to a 200 amp service. The problem i have is where the old panel is located. it is in a laundry room/ closet. I do not have the 30" clearence that i need also the water line, sewage line, and hot water heater are all located under the panel. The inspector recommended that i install an outside weather proff panel then splice all the circuits inside the closet.( Model: HOM30M200RB) Or i can install a disconnect and relocate the panel all together; however, my options are limited.
thanks for any input
sam
