0 members (),
506
guests, and
19
robots. |
Key:
Admin,
Global Mod,
Mod
53........ 120/208 is used mostly because of not only having the luxury of 3 phase for motor applications, but it also avails you to 3 seperate 120 volt circuits from the transformer secondary. If you are using 120/240, you would only have two, because it is a center-tapped single phase. Thanks to the connection of the "grounded" conductor, which would be your common on your three phase "wye" secondary, you have the opportunity for more circuits on a much more balanced load. The more balanced the load, the less you are asking of your neutral. Hope this helps.
Entire Thread
208, 240, & 277 volt questions
aldav53
04/23/06 06:35 AM
Re: 208, 240, & 277 volt questions
earlydean
04/23/06 11:46 AM
walrus
04/23/06 11:59 AM
Steve McKinney
04/23/06 12:20 PM
aldav53
04/23/06 04:26 PM
NORCAL
04/23/06 05:33 PM
Larry Fine
04/23/06 05:36 PM
JBD
04/23/06 05:38 PM
ShockMe77
04/23/06 07:24 PM
Obsaleet
04/23/06 11:27 PM
frenchelectrican
04/24/06 12:01 AM
aldav53
04/24/06 01:33 AM
caselec
04/24/06 01:45 AM
kencr
04/24/06 01:49 AM
aldav53
04/24/06 01:59 AM
caselec
04/24/06 02:07 AM
aldav53
04/24/06 03:27 AM
Larry Fine
04/24/06 04:54 AM
Larry Fine
04/24/06 04:55 AM
aldav53
04/24/06 05:06 AM
WFO
04/24/06 11:22 AM
Larry Fine
04/24/06 02:29 PM
aldav53
04/24/06 02:47 PM
Roger
04/24/06 04:16 PM
aldav53
04/24/06 05:54 PM
gfretwell
04/24/06 09:09 PM
Scott35
04/25/06 08:56 AM
Larry Fine
05/07/06 10:10 PM
Roger
05/07/06 10:37 PM
e57
05/08/06 12:00 AM
Larry Fine
05/08/06 12:16 AM
Larry Fine
05/08/06 12:32 AM
Larry Fine
05/08/06 12:43 AM
PCBelarge
05/08/06 02:28 AM
georgestolz
05/08/06 03:36 AM
JJM
05/08/06 06:35 PM
LarryC
05/08/06 07:51 PM
e57
05/09/06 12:29 AM
e57
05/09/06 12:42 AM
Redsy
05/09/06 01:00 AM
Scott35
05/09/06 02:04 AM
georgestolz
05/09/06 04:00 AM
aldav53
05/09/06 06:55 AM
SolarPowered
05/09/06 07:47 AM
