If he wants to spend the money you do a directional bore underground where the asphalt/pavement wouldn't be disturbed. Around here most companies that sub that type of work charge $10/foot or a $400 minimum. They even install a pull string for us in the pipe.
This is assuming you have some sort of grass or dirt area for them to bore to and from
[This message has been edited by Rich R (edited 02-03-2006).]
