I need to get power out to a pole sign in front of a bussiness. The sign and two parking lot lights were feed from an under ground pipe run that was crushed or broken years ago. Owner who is a friend of mine does not want to cut the concrete and have to patch it. I was think of going over head with triplex. It is only about 25-30 feet from the building. Would this be the way to go or sould I tell him that he has to cut the pavement. I have never done a I set up like this over head. If it was not a friend I would suggest someone else, I still may do that though.
