quote "You can bend RMC however you can as long as you do not damage it."
My answer probably belongs in the confesionals thread. I have done it once with a 2" grc mast that did not penatrate the roof, but needed an ofset. It was before I bought my first triple nickle bender. I was working on a beach house right in front of the Banzai Pipeline. I filled the pipe with beach sand and used a propane torch with a large end on it to heat the pipe up. It bent perfectly. House is still standin.
