Kinda had that happen with switch boxes. 48" is right in the middle of the joint when the rock is hung horizontal. The taper will just run the paper tape right over the openings on the first coat. Subsequent coats can fill on the top and bottom and if someone new didn't know there was supposed to be a hole there whatever was left can get patched and sanded.
-Hal
