ok let get this matter straghten out a little here ::
One of the three has a single 2hp motor with a voltage rating of 208 delta/ 360 wye,
is this motor is european designed ??
if so you have suppy of 240 volt 3 phase right now and one of the motor[s] need to buck down to 208 volt to run propely
merci,marc
