I have the 1-1/4 bender with the lever. I weigh 150lbs as well. I think the 1" HW is harder to bend than the 1-1/4 TW. Also, if I know I'm bending 1-1/4 TW I buy the other EMT from the supply house. They have Allied, and then either Wheatland or some inch-marked kind. I get the non-Allied because it bends easier.
I rarely bend with it alone. Even if I'm using it with my friend who is 200lbs+ we'll both get on it. I think I've used it enough to justify having it, it has come in very handy.
Between the hickey and the bender, I think the bender will lend more versatility when you go to use it on EMT. Like you said, with the HW, you're better of with pre-bends.
[This message has been edited by Jps1006 (edited 01-12-2005).]
