"If you've got some questions on VDV please ask away!"
OK Bill, here goes.
I am doing work for a restoration company that does flood and fire restoration. They want ne to do the CATV and phone. Nothing fancy, just voice and cable TV.
Should I get some sort of termination panel and run home runs to each location? Most of these homes had Cat 5 just daisy chained. With the budget I have to work with I wouldn't want to use a real costly termination center. If there is TV in 4 or 5 locations, I don't see how to do it without multiple home runs. You wouldn't want to use a bunch of splitters would you? How about one big splitter?
Also, should I keep the cat 5 and coax away from the romex, drilling separate holes?
Oh and for the phone, do you hook up for two lines right away or just connect the primary line in each room?
And with the cat 5, are the extra pairs just for noise supression or are they sometimes used to carry voice/data? In other words, is cat 5 capable of more than 2 lines?
Well as you can see I am as green as they come, hope it's not too many questions at once.
By the way, is it common to use a 66 block in residential or is it overkill?
Thanks, Brian
