Dave, Did you get this one sorted out?. What I would be tending towards with the fridge is either a faulty thermostat (switching contacts not closing properly) or a faulty RFI capacitor. Failing that, I'd check the contacts on the receptacle for a loose connection when the plug is inserted. What I'd also check is the Equipment grounding, as many RFI capacitors connect to the ground of an appliance.
