Be sure you have not gone below the minimum equivalent impedance that your amplifier can drive, or above the generally accepted 16ohm max. http://www.termpro.com/articles/spkrz.html As you change the load impedance (adding speakers), the amplifier has to provide power a bit differently, and depending on the quality of the amp, it may be better able to provide the rated power at a particular load impedance.
