Assuming that the wiring isn't too old, it will most likely be the standardized modern system which is used across most of Europe:
Hot = Brown or black
Neutral = Blue
Ground = Green/yellow
I've heard that some parts of Norway use an ungrounded system however, so the blue may actually also be a hot wire in some homes.
[This message has been edited by pauluk (edited 08-24-2004).]
