Joe you seem to be ignoring the fact that the UL book section for the tapping connector I posted references 334.40(B) that makes them one and the same.
Different looking devices but covered by the same requirement, no?
Maybe UL is recognizing more products under that section then they used to.
Looking at it from another direction.
If these are suitable NM taps in a manufactured home how can it be said they are unsafe or unsuitable for stick built homes?
This is all academic as I will probably never use these connectors.
I do use Re-Locs on MC cable and it seems to me that these are nothing different then re-locs for NM cable.
