In the "old" days in Britain, the line came straight off the exchange batteries which were held at a nominal 50V DC. These days, it seems that the modern digital exchanges regulate it down from a slightly higher voltage. When a linecard goes bad (as seems to happen quite regularly in my local CO -- so much for modern reliability!) the voltage goes up to a little over 60V.
By the way, test voltages which exceed the usual nominal can also be applied to the line during routine tests as well.
i don,t know if your phone can hurt yoy,but just look at your bill every month,now thats a shock
You gotta stop calling all those 900 numbers! [Linked Image] [Linked Image]
[This message has been edited by pauluk (edited 06-01-2004).]
