The old Wiggys
are classics.
However, I recommend the Ideal Vol-Con Elite w/shaker (Ideal P/N 61-092):
http://www.idealindustries.com/IDEAL-EZ/products.nsf/ItemMasterLookup/p61-092?OpenDo cument In addition to Voltage determination up to 600VAC (with shaker feature), it'll test for up to 200VDC, continuity (with audible sounder and LED), AND it'll act as a ticker (Non contact voltage indicator). It lists anywhere from $58-$90, depending on where you go.
(If you want to check out Ideals other testers, click here:
http://www.idealindustries.com/tm/ElectricalTesters.nsf/ElectricalTesters?OpenFrameSet )
I had the 61-090 which was the same thing, but w/o the shaker... got it on clearance @ Grainger for $38. I got it as a "too good to pass up" toy a few months back, but fell in love with it. It replaced three separate tools I had (differentiating neon circuit tester, ticker, and continuity tester).
Unfortunately, it got stolen with the other stuff from my truck. But I guarantee you, I'm buying another one within the month!
[This message has been edited by DougW (edited 04-28-2004).]
