I have a question about wall ovens. I had to check a line out from the panel up to the in a wall oven. I pulled the wall oven out(2 year old GE). There was a bad splice in the 1900 box. What the electrician had done was he coiled the slack of the Romex up and left it on top of the stove alomg with the splice box. No way should the Building wire be on the stove, right? I would think the stoves are double walled, but I am going to re-do the splice and keep everythin off the top, and put it behind the oven, right?
