Solid wire is easier to push into a pipe. Stranded wire is a little easier to work with. Unless it's XHHW and the insulation is melted into the wire. We have ran into this problem with all the wire we are using on our current job. Someone told me Stranded is a better choice because it has more surface area to carry the "juice" on.
"If common sense was common, everyone would have it"-not sure, someone here
