The wood trim (brick mould?) is the usual spot for new installs. Easier to run the wire inside the interior molding and through hole drilled in floor hidden my trim pieces.
My house, however, has a cast bronze mailbox/doorbell button combo - which required ripping into the inside wall to replace the wire. Luckily, the button size is the same today as it was in 1934!
