I've always told my apprentices that asthetics is 90% of the job. It doesn't matter how good of an electrician you are because it won't matter in the end. If you look good and the job looks good and something goes wrong that you have to fix, the job still looks good. If the job looks like a nightmare but everything works perfectly, it still looks like a nightmare. What matters is what the customer thinks of you and the job you are doing. That doesn't mean you have to cut corners on quality. All "Yes, Maam" and "No, Maam".
I also give my 2 top rules that HAVE to be followed:
1) Don't "dis" your master.
2) Don't "dis" the customer.
Blessings, Mark
