Similar constraints apply to transformers: Although not a problem for small xfmrs in appliances
Ahem... This is not what I have been told. To cut cost on small transformers, the iron core is made as small as possible which means that the headroom is so small that a 60Hz core reaches saturation when used on 50Hz. There are reports from travellers confirming that overheating is a problem.
