If I have a DC motor with 4 speeds controlled by a multi tap resistor such as in an vehicle HVAC blower this makes the circuit resistive/inductive. My question is, when the motor is running on a lower speed, and say the motor is getting older with bearing wear, will the motor draw more current through the resistor? I know that voltage is required to push current thru a resistor and I know that a motor will pull more current when voltage drops to maintain power, but will a motor load pull additional current through a fixed resistor to maintain power as it ages?
I guess another way to put it is when the motor gets loaded heavier will it pull more current through the fixed resistor if voltage remains the same?
