Quick question: When a job calls for ADA compliance, how high so you mount the receptacles?
Every print I’ve seen only says “comply.” No elaboration. Have tou ever read the ADA?
“Experts” will produce sketches that are copied from an appendix to the ADA. You are told these are the requirements. Yet the sketches and the text of the ADA itself plainly state that the sketches are NOT part of the code.
