Electric storage heaters are the common way to heat watere in Scandinavia, here in Norway we have had pretty much problems with those socets on heaters with more than 1500W elements, so new storage heters are not alowed to have schuco plugs unless the effect is less than 1500W (we have had 2kW storage heater in my home since 1988, and never had a problem)
![[Linked Image from elsjekk-as.no]](https://elsjekk-as.no/images/Blogg/varmtvannsbreder_brann.jpg)
By my opinion, it is not the plug and socket who is the problem, but for the most how the wire is terminated in 1) The plug, and 2) The socket. I keep an eye on such things and on 2 washing macines, I felt hot plugs, changed the molded plug to a new one, and the problem was solved. It seems to be important to use end ferrules.
![[Linked Image from i.ebayimg.com]](https://i.ebayimg.com/images/g/EjIAAOSw9-hciG9J/s-l640.jpg)
