In the second video that JW posted, which I will link to below,
he tried the over-voltage test (device is meant to trip @ 270VAC)
and then there was the actual arc-fault trip test, where loose connections SHOULD
cause the device to trip.
The results are quite disappointing, especially from a company that I thought made quality
electrical controls equipment.
Have a look:
JW 2nd set of tests
