Reno: You said... "For my house, I used a small "All in one" at the service drop. At $45, the unit cost less than most simple meter bases. With only 10 spaces, this panel isn't very large- so I use it to serve a second panel inside the house."
All-in-ones are not common in my area, and I am amazed that you can buy one for under $50!! You are referring to an enclosure with a meter socket, main OCP, and branch circuit bus space, correct??
