Here is the details of the scope probes I have.
1st probe is an older model
TEK P6105
Attenuation: 10x within 3%
Input Resistance: 10 Mohms
Input Capacitance: 10.5 pF
Compensation Range: 15 pF to 47 pF
Bandwith: (-3 dB) At least 100 MHz for the 1st and 2nd meter
Max Input Voltage: 500 volts (DC + peak AC), derated with frequency
2nd probe is brand new
CIRCUIT-TEST OP-100A
Attenuation: 10x
Input Resistance: 10 Mohms when used with Oscilloscopes which have 1Mohms input
Input Capacitance: 13 pF
Compensation Range: 10 to 30 pF
Bandwith: DC to 100MHz
Max. Input Voltage 600V CAT I, 300V CAT II (DC + peak AC), derating with frequency
