These pictures shows a homeowners attempt to install a new spot light on the side of the house up higher than the original light fixture.
It also shows a motion sensor and plumbing pipe being used to get the wire into the new electrical box.
Last but not least the surface mounted box that the light is attached to wasn't rated for a wet location.
Harold
[Linked Image from electrical-photos.com]
