Originally Posted by LarryC
I suppose you could tin the wires beforehand. I think that is what Halo does with the wiring in their RC cans.
I disagree with the tinning of stranded wire and then inserting it into a screw tighted connection. When you tin the wires, and then compress them, the solid mass will sometimes fracture. This leads to a loose connection. That is why soft copper ferrules are used with fine stranded wire when using screw down connectors.
You may be right about that Larry. All I know is that it seems to be an industry accepted practice from way back when.
I know when I replace the keyed brass sockets on lamps, I often see factory tinned wires wrapped around the screw terminals. I do also see those short crimp on copper fork terminals or the brass crimp rings on the end of the wire being used quite a bit as well though.
