OK, back down memory lane, I can't recall if the mini-breaker was edison based only, or came as a S-type.
Working within the older inner cities, fuses used to be 'king'. One EC I worked for back in '70s had barrels full of edison base fuses, with the majority being 30 amps.
Fused resi is for all intensive purposes gone in the twp I work in.
