Lostazhell
Scott... You should really bring this up to them... they might even let you test the prototype Leviton with a serial number!
I contemplated adding the Cut-Sheets to the Submittals package as a bit of humor, but decided against it, as this job has insane specs!
I am submitting cut-sheets on EVERTHING!!! including Tape!!!
On the other hand, the Architects are really pushing an expensive design, so they might actually want to use the Wattgate Receptacles, and hire me for performance research!
Scott
