If you use a laptop it will usually have the ability to detect low battery and shut down.
If you use a desktop, just wire in a parallel power switch and power it down before you shut off the car ... if you can remember. Unless you are actually doing something, most PCs will tolerate just being turned off. My wife's standard procedure for any computer glitch is pull the plug.
