Hotline, thanks for the links. Pretty much gives me the answers i need. Looks as if it's written in a manner that pretty much suggests you get a permit for damn near everything other than replacing a bad receptacle. Guess that's how they cover their butts.
Reno, if i'm interpreting it correctly (and i may not be), you could replace up to a single pole 20amp breaker. This way the amps is 20 or less and the volts are less than 150.
