Originally Posted by djk
Surely in this day and age we should be able to replace the isolation transformer approach with a 10mA RCD protected socket.
Dave,
They aren't only in hotels over here, you were required to have an isolating transformer type socket in your house before the advent of the RCD, a LOT of houses here built in the 60's and 70's still have them.
I remember taking one out during a renovation job, because "it was never used", the guy in the house used disposable razors.
Anyhow, I unscrewed the plate from the wall and out fell the transformer, it was hot enough to make a decent burn in the carpet next to the vanity.
This is what is in a a lot of peoples walls, live all the time (the switch on the front, isolates the secondary side, not the primary).
Just hope that birds can't get into your bathroom walls.
I took the thing outside and measured it with a multimeter temperature, I got 218C. eek
I'm not keen on RCD's, but anything has to be better than a fire hazard in your walls.
