I installed several Leviton 600w slide dimmers in a church and each dimmer is running 4 recessed lights on a seperate 20a circuit with 60 watt standard flood bulbs. The problem is that the dimmers are getting hot, almost too hot to touch. What is going on?
The Golden Rule - "The man with the gold makes the rule"
