The problem is that when I looked, the blue circuit is actually landed on the black phase...
So is it just doubled up on the same breaker (black and blue on the same breaker),
or is the breakers on the same phase in the panel? If it is on the same breaker, then it is considered the same circuit and there isn't really a problem. I assume otherwise...
Evidently it's been operating that way for awhile without any problems that are known about.
There probably wasn't enough load on the circuit to load the nuetral wire to the point of overheating.
let us know...
