lock out and tagged is good but like i said dont forget to check your hot gloves each and everytime you use them that means checking for cracks and punctures in the rubber and making sure they hold air no pin holes if they do and that they are not expired and in need of retest i see lots of guys who dont test each and every time like i said it could mean your life one day (safe habits will keep you alive)also dont forget to check the leather coverups make sure no slivers in them also make sure they are rated for the voltage your dealing with.
