"I'm also none too happy with the supporting of that panel. It looks like the only thing holding it is a couple of cut metal studs and the drywall."
It has the emt for support and if thats not good enough,.. drywall. -jk.
This cement it sounds like I need to bust it up far back enough and deep enough to cut the conduits and put in 90* bends, then take it over to the wall, and up.(or a concrete tight coupling)
The walls arent concrete, but the ceilings are. So abandoning these wires and feeding what needs to be fed isn't an option.
Yes, that is low volt, straight into concrete.
I do need to know if that many tandem breakers are acceptable?
