3rd breaker up and the 3rd breaker down have a lot of insulation stripped off for being a pro job,
I seriously think that burnt neutral is only resting on the front of the neutral bar! eek Do you have anything in your home that sporadically goes off and on? or worse if thats a multi-wire circuit eek
Your panel has the Crouse Hinds "skinnies" that like to fall out of place if you breathe on them wrong, I'd recommend not pulling your deadfront off again unless you are a qualified electrician.
And as much as I despise Crouse Hinds thin breakers (they get Zinsco-itis very easily, and seat about as well as... well see the picture crazy ). they are what's listed to be used in your panel.. (And you won't find them at Home Depot or Lowe's(I think I see a Murray MP-T215 that doesn't really belong in there also)) Someone correct me if I'm wrong, but I don't believe these are CTL. Then you would be able to make room in there for additional circuits if needed.... But....
Please address the forementioned issues with a qualified electrical contractor in your area!
