One method used to keep from going back to lower voltages uses semconductor diodes as part of the circuit. Once the PIV (peak inverse voltage) goes above the level for the lower voltage,the diode opens. I haven't seen one of those in quite a while. I heard that manufacturers were no longer using that circuit so that ballasts COULD be recycled rather than ending up as land fill.
