There is another way to solve the storable vs permanent pool question in a more practical way. What kind of equipment are they using? Storable pool equipment is not the same as permanent equipment and they are mutually exclusive in their labelling. You can't use one on the other. If they say this is a storable pool, want bonding relief and still use permanent equipment there is your violation.
Storable equipment is usually low voltage, always double insulated and has a 25' attachment cord with a cap on it.
Storable pools are usually all plastic and most inflate.
