0 members (),
1,227
guests, and
11
robots. |
Key:
Admin,
Global Mod,
Mod
OP
... Hi gang, I'm planning on running a 60 amp, 240 volt, single phase feeder out to a detached garage to a sub-panel...my question is... do I need a ground rod out there, or will the bare grounding wire in the SER cable suffice?? I'm using 1-1/4" pvc pipe to go underground, but if I don't use SER, and just pull THHN,..does the grounding conductor then have to be insulated??
Thanx....
.."if it ain't fixed,don't break it...call a Licensed Electrician"
Entire Thread
To ground, or not to ground,... that,..is my qwery
Attic Rat
05/04/07 01:22 AM
Re: To ground, or not to ground,... that,..is my q
Gregtaylor
05/04/07 03:19 AM
renosteinke
05/04/07 03:32 AM
Re: To ground, or not to ground,... that,..is my qwery
Gregtaylor
05/04/07 04:31 AM
gfretwell
05/04/07 04:40 AM
Niko
05/04/07 04:59 AM
jdo1942
05/04/07 10:10 AM
Fred
05/04/07 10:37 AM
RonS
05/04/07 10:43 AM
yanici
05/04/07 01:51 PM
resqcapt19
05/05/07 02:38 PM
