It depends on what you mean.
A standard reciver will not drive these speakers directly, at least not well or for long.
If you mean you already have a working system yes you could patch in standard componants.
Your PA amp should have some aux inputs that take phono plugs.
Go from 'tape out' (or any low level outputs the reciver has) on your standard stereo receiver to the AUX input of the PA amp.
You may want to buy a 'Y' adapter so you can feed both left and right chanels into the mono PA amp.
